1
1 device gets kicked from WiFi
I was certain this was a device issue so I replaced the WiFi adapter on my windows pc but I am still getting kicked from the internet. I check my phone during these times and it shows still connected so this is isolated to the pc. This is usually during times I’m using a lot of bandwidth on the device like video conferencing or data extracts.
has anyone else experienced this? Thanks!
    • NW_Traveler
    • 5 yrs ago
    • Reported - view
    Same thing happens to me. I posted in another thread and a user suggested band steering might be to blame.
      • vizzyj
      • 5 yrs ago
      • Reported - view
      NW_Traveler thanks for the reply. I do not have that setting turned on within “eero labs”. We’re you able to get it resolved?
Content aside
  • 1 Likes
  • 5 yrs agoLast active
  • 2Replies
  • 86Views
  • 2 Following
