1
12v Car Adapter for eero 6+
I am looking for a 12v car adapter to power my eero's in my Motorhome.  I have found a couple of eero's in my motorhome work perfectly but using A/C to power them can be difficult.  I see that they actually run on 12v, so a car adapter would be a new item to make money on.  I do not see one on the market yet?   Thanks, Bill
6replies Oldest first
  • Oldest first
  • Newest first
  • Active threads
  • Popular
  • Just buy a Vehicle Power Inverter/Converter 12V DC to 120V AC.
    Like 1
      • Bigbillsd
      • Bigbillsd
      • 6 mths ago
      • Reported - view
      Je655  Not an answer to my question.  I don't always want to keep my 3000w inverter turned on.  Especially when in storage.
      Like
      • Shaky
      • Shaky
      • 6 mths ago
      • 1
      • Reported - view
      Bigbillsd
      What's your specific power brick say on it? I don't know if they're all the same, so reading what it says on your plugs is a guaranteed method to get what you need.
      After you know, it's just a matter of finding a "cigarette lighter' adapter to match.
      Like 1
      • Je655
      • Je655
      • 6 mths ago
      • 1
      • Reported - view
      Bigbillsd according to eero help center eero only uses 3-7 watts of power, so a 3000 watt Inverter might be overkill for your requirements. There are smaller versions that will just plug into your 12v outlets.
      https://support.eero.com/hc/en-us/articles/207625336-How-much-power-does-eero-use-
      Like 1
  • As my original post states they run on 12v.  I am hoping eero will make one as they say using anything other than their power adapter voids the warranty.  -Bill
    Like 1
  • Ok. Best of luck.
    This is what we're all replying to:
    "I am looking for a 12v car adapter to power my eero's in my Motorhome."
    Like
Like1 Follow
  • 1 Likes
  • 6 mths agoLast active
  • 6Replies
  • 34Views
  • 7 Following
Quick links
Community Guidelines
Help Center
Contact eero support
@eerosupport
eero.com
